B
brimis
I installed a new timing gear set in my 84 and need to set the timing, I hope its the timing. When I installed the set I made certain the markings on the cam and crank gear lined up and piston one was TDC on the compression stroke. The car will start right up and idle fine, but when I increase throttle the engine "pops" and "pops" again when I release the throttle, at idle all is fine.
My helms states to follow the vehicle emissions control information on the label on the radiator, only problem is the label is gone. What is the proper setting for the L83?
The helms also reads on vehicles with electronic spark timing to disconnect the EST connector at the distributor to cause the engine to operate in the bypass timing mode. Does the 84 have this EST?
mike
