J
john davis
my 75 vette l-48 with edelbrock performer heads 64cc comp cams 268h edlebrock performer rpm manifold headers into duals no cats and 700r4 with 3.70 gears started running like it didnt have the power it use to have I took it to a guy and he said the timing was retarted real bad cause the hold down had got loose I dont know how much it was off or what it is set at now but it has a slight miss in the engine at low rpm above 2000 rpm the miss goes away the car now runs very strong also if you lug the engine there is a small amount of engine knock not much I have been runnign 87 octane so I put in some 93 the knock is gone but the miss is still there. Do you think the timming is advanced to much? I am not much of a mechanic but I am going to buy a timing light and try and check it my self any tips also which way do you turn the distributer to retard timing? Do you turn it with the engine running if so wont the thing shock your hand? I have a quarter mile marked off on a country road cars hit between 95 and 97 mph does that sound about right with my set up. also does any one have a rough idea how much torque and horsepower I have got thanks jd
