B
brimis
I replaced the timing gear set and finally started the car this morning and the noise is gone! The cam gear had one tooth left from the original stocker causing the timing chain to slap against the timing chain cover. The project took a little longer then expected, but the main importance is the job is just about complete, I just have to install the A/C compressor and bracket. I also installed a new damper along with all the gaskets and hoses.
I thank all that replied, I needed all the help I could get. A special thanks to SCAV for mentioning the nylon teeth on the stocker!
