I've got an issue that I'm trying to work thru with my C5. I've only owned the car for 3 months now, but I'm tired of the extreme noise in the cabin, generated by (I think) the tires. I've read thru many posts about run-flats versus non run-flats is this is NOT another post like that so read on before the flaming begins.
The noise is most noticeable in the rear of the cabin, so I assumed that it must be a rear tire causing the problem, but could find nothing wrong back there. Then I moved to the front of the car and found the beginnings of "cupping" on the inside of both front tires. I assume I need the front end aligned by this find. Now, here's the question part of this thread. 1) Can the front tires cause a loud roar throughout the vehicle and sound like it's coming from the rear and 2) Can I break-down the front two tires and swap the left/right tires on the wheels (thus moving the cupping to the outside of the wheels) to eliminate the road noise?
The car has 17's on the front and 18's on the rear so rotating is out of the question. My first thoughts were to replace all four tires with Michelin Pilot sport A/S (run-flats) after the alignment, but the tires are less than a year old (by the manufacture date) and I hate to spend the money if not required.
Dennis
Dennis
A friend that works at a tire company has told me that the cupping on the front tires can cause a lot of road noise too. My question is more directed towards moving the cupped section of the tire to the outside edge of the tire by swapping the tires
