wishuwerehere82
- Joined
- Sep 6, 2003
- Messages
- 2,316
- Location
- Rochester, NY
- Corvette
- Red '82 Coupe,Sebring Silver '98 Coupe
Well, at least you know where a good one is in Atlantic City.
Patrick said:ITeachFlyin,
The dot means this is a thread you've responded in previously. (But you already knew that from the legend at the bottom of the forum.) The blue color typically means that this is a thread that hasn't had a new post in it since the last time you logged out of CAC.
-Patrick
Patrick said:OOPS! :ugh
I retract what I said before! The blue color apparently refers to the age of the thread, not that it hasn't had any new posts since you last logged in.
Sorry, my bad!
-Patrick
Patrick said:Not to worry, Bill... I'll make you a martini. After about three, all my posts will make perfect sense! :crazy :Silly![]()
Cheers!
-Patrick
iteachflyin said:I think you read county as country ... I'm talking about Rockland County, NY.
iteachflyin said:Patrick, thanks for the clarification, because I really didn't understand your other explanation but didn't want to sound too dumb. I don't understand this one any better but now at least you know I really am dumb!
Bill
Who me?
Who me?
Who me?ron said:Sometimes reliable tire mounting shops are difficult to find. There are many horror stories of damaged rims, etc; but good installations are out there. I suggest contacting yout local Vette or hot rod club and finding out where the members get their tires mounted. Most will tell you that they don't get just anyone to mount tires on very expensive rims. Also, the more modern shops will have the latest equipment and techniques to mount and balance tires efficiently and without damaging rims. I have had all tires balanced with weights mounted on the inside of the wheel. It has proved to be accurate and certainly precludes losing air; plus, I think it looks cleaner.
Ron
PeterG said:My '99 with original equipment GY EMTs always lost air. The amount varied by tire, but often one or two were down one to 9 pounds over a month or so.
Then I made one of the wisest moves of my entire life. I replaced all GYs with Michelin AS ZPs. I used a local garage listed as a TireRack certified installer. The garage is operated by two brothers who supervise and monitor a crew of meticulous mechanics.
They installed the Michelins without damaging or scratching the wheels at all !!! They roughed up the bead seat just enough. I know it was "just enough" because not one of the new tires has leaked any measurable amount at all in the 14 months since installation. Of course I do add air in the winter and let some out in the summer, but the pressures goes down and up equally in all four tires with the ambient temperature.
And best of all, being a little nerdy, I don't have to keep adding air to one or two or three tires to keep them equal -- they are always all the same pressure.
Life guide number 5: If it's supposed to move an doesn't put WD-40 on it.74bigblock said:Just put some tape on them, they will be fine.
