I have a '79 L-82 close ratio 4 speed that I have verified as having the original numbers matching engine. The car is pretty original exept for "Bubba"
installed a poor excuse for a dual exhaust system on it and a set of '80-'81 wheels and 60 series tires. The interior is good but needs the seat covers redone. It has just short of 82,000 miles.
I have been chasing an engine miss that ocurrs when I lay into it and finally took it to a local Vette shop to have them take a look at it. They think it has a lobe on the cam that is going flat. The carb, distributor, vacuum system and everything else are OK. It doesn't burn oil, the plugs are all burning with no signs of oil.
My question to the forum is: given the relative rareness of the '79 L-82 close ratio 4 speed combination on a car that is in pretty decent condition . . . would you replace just the cam and lifters or go through a complete rebuild of the engine? I will need to pull the engine either way unless I can just remove the radiator and "sneek" the cam in with the engine in place.
Somewhere there is a fine line between spending the right amount of money to maintain a 25 year old car and . . . insanity.
