Well things didn't go so good. I gave up on the fuel pump thing when I went to Advance auto and they wanted $300 just for the pump( i don't have a job and can not afford that). Tried to change the fuel filter, but when I tried to squeeze the plastic retainer thing to release the line from the filter, everything crumbled. The little clippy things (garbage) that hold the line on the filter are stuck inside the metal end on the fuel line (and broke offf flush) and Now there is no way to get the filter loose from the fuel line. Looked at a repair line thing so could just cut the old line and filter off, but tried to bend the new vinly tubing to where it was going to hook back up and it kinked off. That surely wasn't going to work right so took it back to the parts store. What a cheese ball way for GM to install a gas filter. Why the hell couldn't they just put fittings on each end of the filter that you take apart with wrenches? I am glad it wasn't my car or it would have been beat to death and then burned for that 3 hours I wasted out in the cold. I did get the spark plugs changed (the old ones had a gap burned to over .100 )and Heet and fuel injection cleaner put in the gas tank. I would much rather work on my vette. There has never been anything on it that I started and could not finish. I am totally frustrated and frozen and I give up. Told my daughter to keep her insurance up so we can burn the POS if it ever quits again.
