V
Vettetrn
I just picked up my 1993 Vette LT-1 6-Speed from the dealer after having the oil changed, OPTI-Spark, Spark Plug Wires, Water Pump, and Heather Core changed.
The car seemed to be running boggy and not to it's normal acceleration or power. I drove the car on a weekend trip for about 400 miles. I got up to go to work yesterday morning and found oil on my garage floor.
I took the car to another dealer for an independent assesment after checking the oil level. It was about 1/2 inch above the full line. The mechanic told me that the car was 3/4 of a quart too high and that my Crankcase Seal was the cause of the leak. He mentioned that perhaps changing the OPTISPARK was the cause if the Crank had to removed and new seals were not replaced or the pressure.
My question is this, can too much oil 3/4 quart cause seals to leak? What other damage can happen?
Tony
Tony
