Vette79
It has been a while since I have posted and updated everyone here on my progress with my '79. Over the past wo weeks we removed the original Torque Converter and replaced it with a Precision Industries 2800 Stall Vigilante Torque Converter with new aluminum pan, gaskets and filter. We also replaced the rear 6'' tailshaft which had new bearing and seal. The disassemble and reassmeble of the components went fine. No problems which in itself I find unusual as there is always something else along the way that is either broke or needs replacing. Now, the vette started fine and we added fluid accordingly. The first two test runs were disappointing. Yes, I do feel a difference by being in the powerband quicker but the lack of initial torque and not spinning the wheels from a stop position is something we were expecting. The only other work we did was removing the AC compressor, new spark plugs, and header gaskets. All relatively simple. So, what should be our expectations with this converter upgrade and/or maybe we installed it incorrectly, which I think is difficult to do. The engine is a SB 355 with 180cc AFR Heads, TH350 Auto, and original rearend. Headers, dual exhaust, 1.6 full roller rockers. I'm running a XE 218\224 CompCam. Some technical experience and insight would be appreciated.
