Need to know the torque specs for the bolts that fasten the half shafts to the trailing arms on a 77. Also I just had my t/arms rebuilt and getting ready to put back in,are there any other bolts that shouldbe torqued in this area? (like bolt thru bushing on t/a, cam adjuster, spring bolts)
The axle drive shaft torque on the spindle end is 75 ft. lbs. and 15 ft. lbs. on the yoke end. The stabilizer shaft bracket to the frame is 120 in. lbs., the bracket to torque arm is also 120 in. lbs. The link bushing bolts are 25 ft. lbs., the camber cam is 65 ft. lbs., the torque arm pivot 50 ft. lbs., the drive spindle support to the torque arm 30 ft. lbs. The strut rod to spindle support is 75 ft. lbs. plus addtional torque necessary to line up the cotter pin hole.
