leadfoot4
Hello from a new member!!
I've been having some issues with my '01's tire pressure monitoring system lately, and I'm looking for some advice. I bought the car new, in June of 2001. The following spring, I put a set of CCW street classic wheels on the car. Mistake #1 was going to a GoodYear store to have the swap-over done.
They managed to put a couple of small mars in one of the wheels, but the biggest problem was that they knocked loose one of the "banded" sensors. I found this out, after I took the wheels to another shop for a re-balance, as GY didn't do this too well either. The tech at the second shop heard the sensor flopping around inside the RF tire and reattached it. I was good for a couple of years after that.
More recently, I was getting error codes from the RF pressure sensor. 99.9% of the time, it was while on my way to work, and roughly in the same place. I could reset the codes, and I'd be OK for a couple of days, but then if I drove the car to work again, more than lkely, I'd get the "service tire monitor" message on the DIC, and it would be the RF tire.
I recently got tired of dealing with this deal, so assumng that the sensor was probably damaged when it got knocked loose, I replaced it, and did the other side as well, just for good measure. After doing this, I did the "relearn" process for the sensors, and was good for a few days. Then I once again lost the RF reading, and once again, while on the way to work. Then, I couldn't get it to reset, and then, I couldn't get it to do the "relearn" at all, as the receiver wouldn't acknowledge the RF sensor.
At that point, I felt that it must be the receiver, so I eplaced that. Again, I was good for a while, but when I drove it to work, I got the Rf error. has anyone else experienced this? Any other ideas on what might be causing this?
Thanks in advance!
Thanks in advance!
