O Vette
I got the message "Service the TPMS. The pressure for each tire was XXXX. Brought it in to the dealer and they said the left front sensor was not working and that if one sensor failed the "Service TPMS" message would appear and none of the sensors would work. They replaced the sensor but, had difficulty getting the sensor to "learn." They finally got it to "learn" but, then had trouble with the others. So, they said that it was probably the receiving unit that needs to be replaced and have ordered the part. I'm not sure I have confidence in their diagnosis -we'll see. Now, for my concern. If a sensor is not working it would not report a low pressure condition and, I assume, it would not report a FLAT condition either. I suppose the DIC would give a warning that the sensor is not working and you should check for pressure with a gauge to make sure all the tires have sufficient pressure. This system doesn't seem safe enough to me. You get the "Service TPMS" but you don't know if it is a sensor or the receiver. If you check the tires and find proper pressure, you can continue to drive (presumably to get serice) but, would not know if you suffered a Flat while driving to a service shop. Seems like the system should be able to alert you to a FLAT even if a sensor is not able to report the actual air pressure of a tire. Don't know if I have adequately explained my concern in this message but, there seems to be a serious flaw in the TPMS. Any comments?
