TPS voltage
  • Thread starter Thread starter 89blkvet
8
89blkvet
I am having a hrad time measuring my TPS voltage with the "Paper Clip" method. Is there another way that I can measure this ti get an accurate reading.....Thank you
The parts houses sell a pigtail assembly to make short work of it but I have found the paper clip does the trick though it is a PITA.
Carlo :w
Madvet.com sells them also...
You can always push a straight pin into each of the wires that you need to check, test your voltages, then remove them and the insulation will sort of "heal" around the hole and it shouldn't pose a problem. Tim
