BLACK MOON
Can someone walk me thru this process? I have purchased all new parts so damaging the current bushings isn't a problem.
Thanks all.
Thanks all.
Do you have the trailing arm out yetIH2LOSE said:I ll explain if you tell me if you have purchased the tool to reinstall the bushing retainer
Hopefully you'll find what you need here....BLACK MOON said:Can someone walk me thru this process? I have purchased all new parts so damaging the current bushings isn't a problem.
Thanks all.
:L I think they mean, don't pull both trailing arms out of an assembled car at the same time.BLACK MOON said:Thanks Heaven. The instructions say do one at a time. I'd like to see someone do both at the same time.. Instead of drilling it out I think I'll use a sawzall and cut one end off then push the rest out.
Thanks everyone.
68Roadster said:
Use the drill to remove the retainer Its the easeyest way.BLACK MOON said:Mid america has one for 49 and VPB has a kit for $60 that has poly bushings, sleves and tool. I'm sure about this tool though. Its different than others but looks like it would work.
Ill post a picture of it tonight.I thought I paid just under $100.00 for it.I dont remember who I got it from.But unless your going to be using it all the time Dont purchase one.I used mine once and it now sits in the bottom of my tool box un-usedBLACK MOON said:I really appreciate the offer. Where did you get yours. Is it the one with 2 plates that bolt together. I should have investigated this further before buying the bushing kits I have. The price for the VPB kit is good considering the tool comes with it. I'll email you.
What's everyone's opinion of poly vs rubber for the rear bushings?
BLACK MOON said:............I should have investigated this further before buying the bushing kits I have. The price for the VPB kit is good considering the tool comes with it. I'll email you.
