youwish2bme
I plan on removing everything back there this week before Xmas... Do you guys have any lessons learned from past experience? I've been spraying pb blaster on the trailing arm bolts, the diff mounts and the crossmember cushions. I forsee a sawsaw in my future for the trailing arm bolts.. I have read that I will need to have the spring supported so that I can remove the spring to t/a bolt. Also I'm of the understanding that the only way to remove the lower shock mount is with the special tool.. Beyond that I don't know what to expect... It seems pretty straight forward after the R&R I did on the motor/tranny and frontend this past winter.. Thanks guys.. Dave..
