Whiplash
Hey Bill,
I'm in the process of the same project on my 71. The picture you posted looks exactly like the way my car is set up. The bolts seem about an inch and a half farther forward than the spring when the spring is loose. I think what you have is normal.
Keep posting your progress. I'm following closely
Not sure yet what I'm going to do about the bearings. I've got all the sandblast equipment to clean up parts and paint but not sure how I'm going to address the bearings and pressing in the front bushings yet. The rotors must have been serviced before because they aren't rivetted anymore. I think the spindle on one side must be new too because the wheel studs don't have the proper stamping on the ends.
Any info on assembly of the bearings and pressing of the bushings you can post would be great.
Your project looks like it is moving along. Good luck.
Whiplash
Whiplash
Bill75 said:I've always wondered why the rear spring holes don't line up better with the spring bolts, the centerline of the bolt to the centerline of the hole in the spring measures about 1 3/4 out of alignment almost equally on each side of the car. I do know that the previous owner replaced the rearend cover and the spring but things look straight and the spring looks to be in the proper location on the rear end. It actually couldn't be made to go far enough forward to make these two things line up. Is this normal??? It sure doesn't look right to me but I can see any signs of any alterations in the car or any reason why this should be.
Bill
