jeepie
I have started my winter projects, I am on the rear trannie seal leak. There seems to be some play in the extension case bushing, not a lot, but some. Since it is a pia to get the drive shaft out I really do not want to do it again so I figured since everything was apart I would change the bushing too. Now the questions:
1) How much play is normal, is a good bushing pretty tight ?
2) The GM dealer says that the bushing is not available and you have to buy the entire extension case, does that sound right?
Thanks for the help.
Al
Al
