VetteVirgin
As these projects typically do, my M20 tranny swap in the 61 has escalated into a slightly larger project with a few questions.
During removal of the M21 I discovered a 153 tooth flywheel with an 11" clutch, the correct 553 bellhousing with no front cover, block mounted starter (reason for no front cover?), and a "custom" Hurst shifter with welded-in shift handle.
I already planned to replace the shifter and linkage, so that was no big surprise, but the 153 tooth flywheel and 11" clutch was unexpected (if I'd looked more closely at the starter bolt pattern the flywheel wouldn't have been a surprise either).
This is all attached to a early 70s Gen 1 CE block 350.
I already have the correct 61 throwout bearing, fork and pivot ball.
Note: The clutch on the 12" flywheel was actually a 10.5", not an 11.
I am planning to install the following:
Phoenix Friction 57-61 OE replacement flywheel
Pheonix Friction 61 clutch
61 OE starter and front cover
61 OE shifter with muncie linkage
My questions are:
How does the starter bracket/brace mount? I know I saw a diagram somewhere but danged if I can find it now.
I came to my senses and scrapped the Centerforce clutch and Jegs flywheel, so my original question is moot. OE replacement will be just fine for now. Anybody have any experience with Phoenix Friction?
Thanks for any help you can provide!
DT
My questions are:
DT
