Help! Transmission Cooler Line Problems
Straychild
New member
Magna, UT
2004 Base
I have been having major issues with transmission line leaking. I have had this into the shop 6 times since June. The issue seems to have appeared after I had new sway bars installed. (Cultrag Performance Sway Bar upgrade Kit) The dealer is having major issues with my DeWits seeming to think it doesn’t have standard fittings. It appears to me that they just jammed the sway bar in and it is hitting the cooler line. I had the Radiator in for a year without issue prior to the install of the sway bar. Has anyone else had similar issues? If possible I would like to try to correct myself rather than take it back to the dealer.
2004 Base Corvette
