A1Avette79
Speedo stopped working a while back - needle jumped for a couple days, then stopped working altogether. Finally got underneath and pulled the speedo cable off the transmission. The tip of the speedo cable had broken off and the nylon driven gear is scored and the sleeve is worn. I can't find any record from the previous owner to indicate that the gear was ever replaced. There is, however, a record of the speedo cable being replaced back in '93 (40,000 miles ago). Whoever did the work installed a single cable and bypassed the cruise control but I don't know if they replaced the gear or not so I don't know if the one that is installed now is original. The gear that is in now is a "natural" color 22 tooth. Either way something caused the speedo cable to fail after only 40,000 miles. I never checked my speedometer for accuracy before now - never thought about it until it stopped working.
When I checked on line to order a new driven gear I couldn't find a "natural" color 22 tooth gear - only a silver or gray one. I wanted to use one of the gear calculators on the internet to make sure the gear was correct before i buy a new one but i need to know the size of the metal drive gear to use the calculator. Unfortunately pulling the transmission out to look at the drive gear isn't an option.
Was there a standard size and tooth count metal drive gear used on a '79, automatic,L48 with a 3.55 rear end model (i am assuming i have a 3.55 rear since that was standard in '79)?
