76okievette
Folks I am going to do a transmission fluid change on my 76 and was wondering if there are any tricks I should be aware of?  Mine is leaking and I know one of the bolts will not tighten so I am hoping I can retap the bolt hole and get the bolt to hold.  What else should I do when I have the transmission pan off?  Any suggestions on the gasket and fluid type I should use.  Thanks for all your help.
