VAroute66
I know the kits have all the mid-year mounting issues addressed, but does anyone know if the Tremec trans mounting pad is at the same relative height/vertical position as the munice mounting pad? I know that you can't really modify the exsiting factory mount, and I know that the Tremec mounting pad is further forward to accomodate its greater length, so conceptually you would have to shorten the bracket. Would the stock mounting bracket position have to be vertically adjusted? Thanks!
