D
Donw
I have a 350cu 300HP 1969 Corvette. Just replaced the linkage and it seems ok except there is a back line cable or some name like that. It is suppose to hook up to the reverse arm It is stuck other then being able to pull it a little. Is this needed? Also the little steel wire that I believegoes on to one of the bards too.
Other problem, sometimes I can go out and it will start up and run great. Turn it off make some changes or whatever, come back and it just cranks trys to start but won't. Any ideas?
It has original 350 block but heads are off a 74 or so. Do I still need to run premium leaded in it. Thought that might be the starting problem. Plus it is the original Roochester carb.
Any help would be greatly appreciated.
Don
Don
