Totalamnesia
I'm trying to take the dash off of my 79' Vette so I can check the headlights out. I'm having a bit of trouble. Can anyone help?
.I'm trying to take the dash off of my 79' Vette so I can check the headlights out. I'm having a bit of trouble. Can anyone help?
Are you trying to remove the whole dashpad or just the speedo/tech? If the speedo tech, loosen the 2 bolts that hold the steering column to the support bracket so it will drop down. After you remove the screws holding the speedo to the dashpad, it will pull forward.
Gary
