Spinman
- Joined
- Oct 30, 2003
- Messages
- 30
- Location
- Cleveland, Ohio
- Corvette
- 1990 C4 L98 Coupe (original owner)
Just ran across this TSB:
Model and Year: 1986 - 1992 Corvette
Condition: Roof Panel attaching bolts rattle
Cause: Retainer assembly may allow the bolt to rattle
Correction: The new roof attaching bolt retainer P/N 10193699 must be used with the new silencer P/N 10218584 which holds the bolt in the retainer. Prior to installing the new retainer, insert the bolt into the silencer and then install this assembly into the retainer cavity. Install the new retainer / silencer / bolt assembly on the vehicle using the procedure found in Section 10-9A-5 of the 1992 Corvette Service Manual.
1) Has anyone installed this fix? Any improvement?
2) I don't hear a bolt rattle per say, but one bolt refuses to remain tight. I need to tighten it approx every 400 miles. Was thinking that this fix might help in that regard.
3) Does this apply to all 4 bolts or only 2 of the bolts?
4) I have two tops - should I order 4 or 8 retainer / silencer / bolt assemblies?
5)Can someone post the instructions from the manual..
Thanks -
Thanks -
