01MYZ06
Anyone heard if a TSB is coming for the lower front control arm/bushing issue? I know some Tech's are swapping out the smaller diameter rear bushing washer with the large diameter front bushing washer. While this helps minimize the control arm from gouging the subframe, the control arm is still sliding back off the bushing to the rearward position, which causes decreased caster settings, it also throws the front toe off.
I can't believe GM is just going to keep swapping out lower front control arms or in extreme cases that go unchecked, the front subframe too. My subframe has some major gouging showing and I know of many other C5/Z06's (mostly Z06's) with the same problem. I don't see the point in getting the arms swapped out if it's just going to do the same thing again in a couple of months, throwing off the alignment in the process. Seems to me that if a control arm can slide off it's bushing then a significant design flaw exists.
01MYZ06
01MYZ06
