(snip)
TPI rules
:L
otfl
in the torque department.
In 18 years of writing in-depth coverage about GM Powertrain products, I was bound to get some of the numbers confused...admittedly a piss-poor excuse.
I should have known better than to post to a discussion on engine specs and trivia that involves "nelson84" without confirming some of the numbers in the 24-model year collection of Chevrolet and GM media information I have stored up in the "stacks" above my office. I mean, hey the stuff was just up the stairs, but...I digress.
In seven model years of production, the L98's peak torque was specified variously from 330 lbs/ft to 350 lbs/ft. Interestingly, in the final year of production, MY91, GM quoted two numbers which were, depending on what part of the corp was dispensing the data, either 345 lbs/ft or 350 lbs/ft.
In five model years, the LT1's peak torque was specified variously from 330 lbs/ft to 340 lbs ft.
So, on one narrowly-focused issue, the L98's peak torque, "nelson84" is correct and I was wrong. Depending on what model year and what source you use for the numbers, L98 had between zero and 20 lbs/ft higher peak torque than did the LT1.
But (actually it's a big "but" so let's set it in all caps)...BUT, when you look at the full torque curve of each engine, the L98 sucks hind tit compared to the LT1. When you consider torque curves, people who actually know about engines (as well as knowing the their peak numbers) understand that it's the torque curve in totality that makes the car accelerate well.
I have the 1992 Chevrolet media information open on my desk and in that book, GM published a comparison chart of the L98's power and torque curves vs. the LT1's power and torque curves.
Looking at this data, right away one can see that the L98, by virtue of the long intake runners of the "tuned port" injection, is actually quite peaky, with a strong "hump" in the torque curve that begins at 2500 rpm, peaks at 3200 rpm and ends at 3600 rpm. In fact, that narrow range, 2500 rpm to 3600 rpm, is the only place the L98's torque exceeds the LT1s and in 1993, a camshaft change added 10 more lbs/ft torque to the LT1, decreasing the L98's lead in that range.
Everywhere else in the torque curve, from idle to 2500 rpm and from 3600 rpm to the L98s rev limit, the LT1 has more torque and it continues to make torque for 700 rpm beyond where the L98 quits. For example, at 1000 rpm, the LT1 is up 10 lbs ft and at 4200 rpm, the difference is huge with the L98 dropping off to 270 lbs/ft and the LT1 at 325 lbs/ft.
Obviously, the disparity is even bigger when we talk about power, with the LT1 making between 50 and 70 more horsepower, depending on model year.
Yeah, the L98's torque peak was higher, but the reason a stock 92-96 Corvette with the LT1 could clean the clock of any stock L98-powered car in a drag race, in a 0-60 contest or any other kind of useful acceleration contest, was the LT1's fatter torque curve.
So, "nelson84" is correct in saying that the L98's torque peak is higher, but he's wrong when he says the L98 has "more torque."
As for the persistent rumor which "Schrade" discusses, ie: either of those engines can vary injector pulse width on a per cylinder basis....it's urban myth. L98s used one pulse width for all eight cylinders. LT1s used two pulse widths, bank 1 and bank 2. In addtion, pulse widths were varied only when the engine was in closed loop. At WOT, the engines ran in open loop and on the base fuel schedule in the calibration.
