I
IRISH KELLY
Does anyone know approximally the round off figure cost to have an auto shop do a tuneup plus replacing the spark plugs would like to know the low$$ to High$$ thx;help
Really depends on what you are going to have done. Are you replacing the optispark or just the cap and rotor? The parts alone can run a few a bucks. I'd consider doing it myself if I were you.
Lets try this...and anyone can feel free to speak up about pricing here, I'm kind of guesstimating this, but...
Opti, 150 -510 depending on if you do basic cap/rotor up to 510 for an MSD like I put on.
Wires 50-100 depending on brand and type, you can get some really good wires though near the bottom end of this range.
Plugs, 16-60, again depending on brand and type of plug...although my opinion is that some of the cheaper AC Delco or NGK basic plugs are just as good or better than the newer high dollar gimmick plugs.
Belt 55
Radiator hoses 75 for the three large hoses maybe?
Thermostat 30
Waterpump 170
Antifreeze 10
Labor? Who wants to guess at this one? I wouldn't be surprised to do all of that for it to run somewhere close to 400.
If it needs to go deeper into the front changing out the front seals and timing chain, someone else will need to speak up because I have no clue at all what that would end up running.
If you are looking at Plugs and wires only, my guesstamite would be:
Parts; Plugs $80, Wires $100
Labor; $200-$400
But if you can work on an MG, you can work on this LT1. It just takes a few tools to do what you are talking about. The first time I changed plugs it took me about 3 hours, I did it in about 1 1/2 hours last time. Now the wires are something else, the way they run is a real PITA, but it can be done.
Hope this helps!
Labor; $200-$400
Hope this helps!
Oh, one thing to keep in mind if you do decide on new plug wires, and hopefully someone will correct me if I'm wrong, but the MSD wires are 8.5mm and will not fit in the stock clips that you route the wires through to keep them in place...Accels are 8mm and I honestly don't remember if that's small enough to go through the clips or not? AC Delco's I would imagine be fine through them....anyways, if you step up to a larger sized plug wire, keep that in mind. I do think there are larger clips you can by too if you do want to go that route.
85,000 Just bought it and do not have any information as it was on consignment with small dealer and I made a deal as I liked the look of it and it seems to drive OK need a little tender care as the sun visors need recovered or replaced, seats not to bad can live with them, body look good I guess time will tell if I got burned or not, but my gut feeling tells me that all and all it will be a nice set of wheels just got rid of my 1977 MGB which I liked but was getting board working on it all the time wanted to try something with a little more get up and GOI forgot to ask, how many miles on your 92? Plug change is really pretty straight forward. The only tough ones are the 2 back ones on the passenger side.
Thank you for the welcome, and thank you for all your adviseWell, I think I can say for a fact that the Corvette will have a bit more get up and go.I'd probably just start with the plugs and see where you are then. If you are still having the "miss" then jump into the wires. Just a thought.
Oh, and I'm not sure that we officially said this:
Welcome to CAC!
Thank you for the info, by the way I am not sure what Opti is perhaps you can let me thanks againI just replaced the plugs and wires, along with a water pump, this past weekend. I used NGK TR55 plugs ($14 from Autozone) and Taylor SpiroPro wires ($78 from O'reilly's Auto Parts). I really don't know how the wires can be replaced without removing the water pump, at least on the drivers side. I had the pump out and I could barely get the wires on.
If you decide to pull the water pump then I would recommend replacing the Opti also. I decided not to replace it (lack of funds) and I still have a slight miss.ad Now I will have a slight miss until the Opti stops working altogether.
Opti...short for optispark...is your distributor. On LT1's, it located on the front of the motor, kind of behind and under the water pump. You can't really see it if you go raise the hood on your car, but if you follow the plug wires to where they disappear at the front of the motor, that's pretty much where it's at...lol.
