TOMGIBSON
New member
i have heard that you can bypass the turn signal flasher that's in the dash and replace it with one under the sterring column. my turn signals only work at times , then real fast, then not at all. 2000 C-5
i have heard that you can bypass the turn signal flasher that's in the dash and replace it with one under the sterring column. my turn signals only work at times , then real fast, then not at all. 2000 C-5![]()
I was doing the same thing as Hoosier and it did work but it slowly got worse until I had to do something else.....![]()
Does.......see post #6 for the link to the fix I used.![]()
Not positive Otter but I'm betting it might. I know it has worked for a lot of folks who have had the same problems in their C5's.....I sold that car over 2 years ago and talked to the guy who bought it from me recently and asked it all was running well and he said no problems......you might shop around and see if its cheaper anywhere else that link is getting old.......but then so are we all.....![]()
