Turn Signal Problem
76okievette
oklahoma
Early 1976 L-48, 2008 Victory Red
I seem to have lost power to just the left side rear turn signal. Everything else works. Anyone have any idea where to look?
I would first check for any ground wires that might be loose or broken on the left side. Also, sometimes a bad light bulb will cause a problem.
Thanks, I tried a new blub and it was the same problem. The ground appears to be good because the brake light and tail lights all work I get power to the contact for the the tail light but nothing on the other wire. I have been working on the interior but I don't see how that would effect just the turn signal. Thanks for the suggestions I appreciate it.
I did not think about that, but the front signals work. Is there just one flasher unit for all the blinkers?
I looked at the wiring dirgram and it appears that each rear signal socket gets it turn signal power seperately from the turn signal switch. I guess this is on the steering columb. Does any one have any input on how to remove this and repair or replace it?
Check for power first at that wire on both sides of the multiple connector between the steering column and the instrument panel harness; if you have power there, it's in the wiring between there and the taillamp. If no power there, it's probably in the turn signal switch. :)
Thanks John, I will check it today.
