Turn Signals are not working
M
mmark2
The turn signals on my 93 started to flicker when they were turned on and now they don't work at all. Checked the fuse and it looks OK (will change it anyways) but is there another fuse or mudule that I should be looking at also???
Thanks Galen, I assume it's under the dash, would you know approx. where under these it might be??
Mine hangs loose under the dash. I have to remove the panel under the steering wheel to get to it. Try the 4 ways if they work listen for the flasher clicking. Turn signals and flashers each have there own flasher but they are next to each other.
Yup, the flashers work fine so it must be the turn signal unit. looked in my Haynes Manual and there's a loose description on how to remove the panel that's covering everything up, but it's pretty vague, what's the best way to take it off to get to the relay, don't want to take my roto tool to it.
