hogbrains
I have a 66 327/350 coupe. The rear U joint rubbed the floor on hard acceleration. I replaced the diff. rubber donut with a poly donut. It rubbed even more. I put spacers in the poly donut and it helped some.
Do I need to shim up the floor with wedges between the frame and the floor or shim the donut more? I ask about the floor because it rubs more with weight in the passenger seat.
Is this a common problem?
