Rebelrob
Since you ditched the emission stuff, might as well loose the cat and ECM. Put on a regular Qjet and distributor. Get your initial timing up to as much as your engine w/ tolerate and curve your dist. so that mech. advance is all in around 2,500 to 3,000. Without cam and higher CR, that's about all I can think of. Make sure your coil and plug wires are good. My $.02![]()
Hi, I have been reading this post for 82 vette. So basically if your having headaches with the crossfire set and ECM, emissions and all the electronic fuel injection. You can just basically remove all this, and install a normal intake manifold and place a decent carb on top with a new igintion/distrbutor?
