Don61
Hey everyone, Hope everyone is doing well. I haven't been on here in awhile due to a lot of life circumstances. But I've got a problem with my 81 vette that I've been working on for a year & still can't get fixed. I posted about it on here a long time ago but couldn't find a cure.
Anyway, my 81 vette, original 350 motor & 350 trans. I changed the HEI distributor to a non-computer controlled HEI, changed the computer controlled quadrajet to a 1406 Edelbrock 600cfm carb & installed a thermostatic switch for the electric fan. I removed the smog pump & related hoses & all of the plastic ducting for the original air cleaner. I installed an Edelbrock 2" thick air cleaner. I installed a new carter fuel pump, a inline fuel filter,fuel pressure regulator & gauge. It easily holds 6lbs of pressure. I used heat reflective shield on the fuel line from the pump to the carb. I installed an under carb heat shield & even coated it with heat reflective material underneath. I also used a thermo-spacer between the shield & the carb. I even wrapped the headers with heat wrap the best I could without removing them. It has a 160 thermostat & the engine never runs over 185 degrees. Runs well until it gets hot, especially when it's hot outside. Then it stumbles, backfires & stalls, especially at idle. Once it starts running badly you have to let it cool down & it will run ok again once it's cool. The timing is set at about 10 degrees & I've even tried rebuilding the carb. With all of this work it still stalls when it gets hot. When you open the hood it's unbelievably hot under there. Touching the air cleaner will burn you. It had a similar problem when it was all stock but not as bad. It ran worse all of the time stock but didn't stall. It runs much better now until it gets hot.
Any ideas?
Any ideas?
