Hib Halverson
I've gone back and read most of the posts in this thread.
The engine has no problem with the cooling system because the ECT never runs hot. You said perviously that you have 6-psi fuel pressure and you also said your running 10-deg initial advance and that as you raise the rpm the timing advances. The distributor is new and I assume the same about the plugs and wires.
I keep coming back to a lean air fuel ratio at idle and part throttle. That would make parts of the engine run hot.
The symptoms of lean AFR would be poor idle stability and stalling. Surging, bucking and misfire. Those problems would not be present after a cold start and might not be present during early warm up if the choke is slow to come off.
With that Edelbrock carb, you change the part throttle AFR by changing the primary metering rods.
