minifridge1138
Useful information, but off-topic for the radiator.
The fan shroud can be removed without removing the hood, alternator, ac compressor, etc.
With the shroud out, the radiator comes out relatively easily.
The trick with the shroud is you put it in on its side, and then twist it.
I wish I had a better way to describe it.
I start with the driver's side of the shroud pointed towards the ground. It gets about 1/2 way down and then I start to rotate it so that the top is up.
It may take a few tries, but eventually you figure out the geometry and then it just pops in and out.
Good luck!!!
Good luck!!!
