- Moderator
- #1
KANE
Moderator
- Joined
- Mar 2, 2002
- Messages
- 3,244
- Location
- KY
- Corvette
- Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
[FONT=.SF UI Text]Current list of mods on the 82...
[/FONT]
It’s been a journey over the last few years trying to get it to a respectable performance level with its 0-60mph time.
So where has this taken the performance of the ‘82?
The best 0-60mph time I have is now ~4.5 seconds.
[/FONT]
- OE TBI units bored out to 52mm running in parallel port fueling configuration
- Renegade Intake (aftermarket cross ram)
- 90lb injectors
- Aeromotive Variable Fuel Pressure Regulator (25psi at idle / 28psi at WOT)
- Davis Unified Ignition distributor, coil, and module
- MSD Digital 6A capacitative discharge system
- AFR Eliminator 180 heads w/ 65cc chambers (equipped with hyd. flat tappet springs)
- Aluminum radiator and high flow water pump
- Erson cam with .496” / .495” lift, 224/234 @ .05, 112 LS (1.6 rockers on the intake and 1.52 rockers on the exhaust)
- Hooker full length headers
- Dynamic EFI EBL Flash ECM with 8 position flash programmable memory, integrated wide band O2 sensor, and USB compatible
- 1989 Corvette Electronic Spark Control module conversion
- True duals, H-pipe, with Magnaflow mufflers
- 2k RPM stall converter
- Built 700R4
- 3.73 Yukon ring & pinion gears
- Custom 140mph speedometer and custom redline tachometer with 1982 Corvette crossed flags
- LED gauge lamp conversion
- Halogen H4 four lamp conversion
- Restored interior
- Show quality repaint
