C
Cigarman
Those of you who prowl this forum are probably sitting on pins and needles to find out what the next chapter is in my comments about difficulty to shift into reverse/low clutch fluid.
One of the sources I went to is the Corvette Doctor http://www.corvettedoctor.com .
I received an e-mail from Chris and he added the following after I told him of adding clutch fluid:
Check the inside of the car where the clutch rod goes to the pedal and see if you feel wetness at the firewall. If you do you will have to replace the clutch master cylinder. You may also have to replace the clutch if the master is leaking. To much pressure is being applied to move the clutch fork because the clutch might be to the end of it's life. Give it a check, if you find no leak you should be alright.
Well, I checked and it is wet. Looks like I at least need a master cylinder for the clutch.
