Quatrefoil
I'm considering installing a 260High Energy Cam Small Block ( A5780-260 ). New lifters, but new valve springs? Do I add Zinc to oil changes?
If you're on a really super-tight budget, you can get the good wear protection, via high ZDDP content, with light truck diesel engine oils. One of the best is Chevron Delo 400LE 10W30, but it's very hard to find in quarts. The next best is Shell Rotella-T 10W30.
For more information on engine oils and aftermarket flat tappet cams, see this CAC article on engine oil for Corvettes.
Hib -
Not trying to disrespect your suggestions and knowledge but I think I remember reading a year or two ago in one or more forum posts that Shell has changed their formula for the 10-W-30 Rotella and it no longer contains the higher amounts of ZN and PH as it once did. Not sure about their diesel formulas such as 15-W-40.
Tried to do a search because there were a lot of posts about this but the search function seems to have changed in the last few years and I couldn't find anything. Hopefully someone else can chime in with the latest info.
Terry
