Save your money. You don't need to do this. It won't make the car run any better. The improvements people have seen are because the work done corrected other things. If your distributor needs work, the Pertronix won't fix it. Although when you install the Pertronix, you'll probably do the repair work in the course of installing the Pertronix.
The Pertronix system and the others only save you from replacing and adjusting the points. How often do you do that? And how long does it take? It's not a bad thing to get rid of points maintenance. It's just that it's not a big deal.
When the Pertronix or a similar system breaks, and it will someday, will you have a spare? How long will it take you to get a spare? Will you break down at a place and time where it's convenient to get a spare and replace it? If your points break, you can replace them at the side of the road in the dark in the rain in the freezing cold in traffic in 10 minutes with a screwdriver. You can buy spare points for under $10 and carry them in your glove compartment.
If you want a super duper killer spark that'll light up small towns, JC Whitney probably carries something that'll do the trick. You don't need it. Chevrolet ignition systems work just fine.
