Question: Upper A-Arm Ball joint
  • Thread starter Thread starter 78 Shark
7
78 Shark
Hello All,
I have recently removed my upper a-arms and ground the rivets off to replace the ball joints. The ball joints I received from Volunteer Vette have larger bolts than the holes originally for the rivets. Should I drill the holes in the A-arms to accomode the slightly larger bolts?
Thanks, 78 Shark
Hello All,
Thanks, 78 Shark
Yep!!:thumb Thats purdy common with replacement ball joints!!:beer
yes drill them out but be sure you have good joints, especially the lowers. The uppers last a lot longer then the lowers and lot of "kits" on the market have imported cheap joints and they have been failing in as little as 1k miles. Look this up on the various forums, about a year ago this was a big problem and I doubt it's changed much. I use only MOOG parts but they are also the most expensive.
Hey GTR1999 and gmjunkie,
Thanks for the info, I wasnt sure whether the ball joints were even the right one with larger bolts. I dirll them out and a great fit. Thanks again.
78 Shark
