WayneLBurnham
- Joined
- Dec 30, 2002
- Messages
- 304
- Location
- Dallas County, Texas
- Corvette
- '75 Modified Red Ragtop: "LEFTLN"
That seems about it...one other thing
Whatever you do, do not run a small block chevy engine for any significant amount of time, or many others, with no thermostat. That really applies even more if you have aluminum heads.
Without a thermostat or flow restrictor (washer-like, visualize a thermostat, but with the guts gone) the fluid level when running will be too low in the heads - worse uneven. Warping and cracking can result. The thermostat acts like a "stop log" to flow, causing coolant to "mound up" behind it.
I like the slightly larger openings and bleed-off/flow-around designs of the "high flow" or "high pressure" thermostats. They don't actually open directly against water pump pressure like conventional ones and equalize the pressure to some degree on each side of the thermostat. Since thermostats are only $5-10, it's up to you whether to try to get a refund or replacement from GM.
