Vaccum Leak At Back Of Engine
CHARLES
BOSSIER CITY LA.
1998 torch red coupe
1998 C5 6 SPEED MY QUESTION IS . Is it possible to replace the vacuum line behind the intake that operates the doors for the air conditioner, to switch from floor to top top defroster with out pulling the intake manifold? Next question where is the reverse switch backup light switch located on the trans?
HI there,
Unless you have very small hands, no, you will have to remove the intake to access this line. After the intake, it goes inside the wiring harness, to the underside of the battery.
As for the reverse switch, passenger side with a 2 terminal connection.
Allthebest, c4c5 :eek
Once again corrvette action center has saved me $$$$$$$$$$$$$$$$$$$$$
CHARLES :beer
