T
t78
Hi everyone,
What does the vacuum break diaphram do? (I also think it is called the choke pull-off valve). I'm talking about the part right above the choke coil on a stock Qjet. (passenger side)
I've had a hard time getting mine to run below 1200 RPM, and I just determined that this part was bad. (It would not hold a vacuum at all). So I replaced it tonight, along with a new Vacuum Advance Unit.
I didn't get a chance tonight to see if the new parts helped (Because... of course... the battery was dead...), but I was wondering what exactly the vacuum break does. It looks like it just connects to the side of the secondaries and pumps back and forth...
Thank you,
t78
Thank you,
t78
