Shawn's 78
Here's a question(s) and suggested feedback for those that run either Comp Cam XE268, XE262 or NX262.
First here is my set up:
78 L48
Cam (current stock) - well after this weekend, none. I collapsed a lifter and flattened a lobe on the #4 exhaust.
Heads: Edelbrock RPM
Intake: Edelbrock EPS
Exhaust: Supercomp Headers into MA's chambered exhaust
Carb: Holley street avenger (670cfm).
4sp / 3.36 gears
Stock bottom with good compression
NOS Top Shot (100hp). used 5% of drive time (some fun factor!)
I ran the numbers on CamQuest6 (comp cams free software) and cam up with the following (in order) comp cam XE262H, NX262H & XE268H. In other posts I see both XE's used, yet no comments on the NX.
So I would like to know a few things from those that use those cams:
1) what kind of vacuum readings are you achieving (Hg). Is it enough to run the brakes and headlights?
2) which is better for low end torque?
3) Has anyone used the NX262H?
4) Why do you like your 262 or 268?
I have the cam out and will be cleaning up the engine bay this weekend with plans to install the cam the following weekend (nice to have it up and running for Father's day!).
Your comments will help me with achieving the most in HP, low end torque and vacuum for the accessories.
Thanks in advance for your comments! :cool
78 L48
4sp / 3.36 gears
