Vacuum problem. Headlamp/wiper
19724spdvette
New member
London
Hi everyone, new to forum, I have just finished restoring my Ontario orange 72 Vette and all is good except for a small problem.
all headlamps and wiper door work perfectly but when I turn off the car after about 20 seconds I hear a loss of air and the lights and wiper door sort of relax and open very slightly, the every time I restart car everthimg opens before reclosing.
Everything is new, could the new relays be faulty??????
help!!!!
help!!!!
Always a good idea to start out looking at the easy stuff. Sounds to me like you have a small vacuum leak somewhere. The first thing I would do is to check all the associated vacuum hoses for a leak, including right at the points where they connect to a fitting, air motor, etc. Listen carefully to determine where the leak sounds the loudest. If you don't find a leak in the engine bay, it could be coming from under the dash at or near the headlight switch.
Cheers, Terry
Welcome to CAC!!!!
Enjoy!!!
Sent from my DROID RAZR using Tapatalk
Bad connection
Welcome to CAC!!!!
Enjoy!!!
Sounds like you might have a couple of your vacuum hoses installed incorrectly. As mentioned earlier the check valve can be the culprit. There are several troubleshooting guides available on line. Get your self a vacuum pump and start checking the various components.
