valve cover clerance problems
Tighten Up
New member
Louisiana
74 coupe
I am having clerance problems with the alternator hitting the valve cover. Engine is a 454 running roller rockers with pollylocks. Engine has the short water pump with power steering and just the alternator. I am using all stock brackets. Any information would be a great help. Thanks
Roller rockers with conventional poly locks usually won't fit under stock covers and man tall covers won't work unless you relocate the alternator.
There are some vendors with sell polylocks which may fit under stock height covers. I think Crane, ARP or both may offer them.
Or you may have to find a different set of covers which are somewhat higher than stock but not high enough to interfere with the alternator.
On my BBC, I have Crane Gold Race Rockers and ARP polylocks under an old set of B&B polished aluminum covers. They are just a bit higher than stock but clear the alternator in the front and the brake booster in the rear.
Welcome to CAC!!
enjoy!!!
Appreciate the information Hib I will check the ARP locks
