cscarlson
Had to put new valve cover gaskets on my corvette but the new ones leak on the bottom side. is there anything i can do to fix this short of replacing them again?
cscarlson said:Where do you buy this Permatex stuff..?
Just about any local parts house should have it. I agree 100% w/ lt4 gs ... permatex non-hardening on VC side only of gasket ... if it still leaks put some on head side too. Make sure your cover rails are straight ... especially if stamped VC. PNH looks like dookie-in-a-tube ... good as gold. Been around forever ... it’s what everyone used before the advent of silicone ... still best for some apps. Works great on water pump mounting flange-gasket too. The pnh will hold gasket in place on VC very well ... & is nowhere near as hard to scrape off as gorilla snot (3Mwsa) ... but is more difficult to remove than silicone. I believe its present-day correct name is “Permatex® Form-A-Gasket® No. 2 Sealant” ... it is not silicone /not RTV. The #1 is similar but it hardens ... #2 stays pliable.lt4 gs said:I realize that this is older than dirt. I prefer the non hardening Permatex stuff....never had one leak yet. Ask the Chick our resident tech..
