- Joined
- Jan 1, 2002
- Messages
- 7,243
- Location
- Washington, Michigan
- Corvette
- '67 Marina Blue Convertible
After building and working on small-block Chevys for over 40 years, I've found that 90% of the leaky valve covers that come to me leak between the gasket and the cover, not between the gasket and the head surface. The hot oil runs down the inner wall of the cover and "pools" in the crevice where the inboard edge of the gasket forms a "ledge", then it leaks out between the top of the gasket and the cover. I always clean the gasket mating surface on the valve cover thoroughly (and straighten/flatten it, as most are distorted from over-torquing the hold-down screws) and apply a thin bead of Permatex Ultra-Copper Hi-Temp RTV all the way around, with a little circle around each screw hole, and apply the (dry) gasket to the cover and let it set up before installing the cover. This holds the gasket in place during installation and seals the joint between the cover and the gasket, and doesn't damage the gasket later when you remove the cover again; I've NEVER had a leaker - can't STAND oil leaks.
Chevrolet knew this too, just took their time (30 years) fixing it in 1985 when they redesigned the valve covers for the center-bolt 350's as part of their "dry engine" initiative; the new covers were designed so the walls of the covers extend down below the head surface, then turn back up again, so the river of oil that runs down the inside of the cover dribbles off the bottom of the "U" section and can't run "up" the outside of that section to get to the gasket.
