joshwilson3
I'm pulling the valve covers to replace the gaskets and to paint them.
I knew what to expect and have read the articles on how to, but ran into some unexpected problems.
I'm doing the driver side first, then I'll do the passenger side. I ended up having to remove the smog pump brace, as the cover hit the brace. I was thinking all I had to do was loosen the screw.
But I hade big trouble on the other end as the cover kept hitting the metal vacuum pipe for the brake booster. I haven't seen this mentioned in other writeups. Anyways, I had to rnbolt the line from the Plenum. Though, the pipe runs through a piece that is bolted to the back of the head. I couldn't figure out how to get to the bolt so I could pull the metal line. So, I pushed and pulled the metal pipe, then somehow got the cover out by pulling it up and to the front of the engine.
I have no idea how I'm getting the cover back on as that wire harness was pulled tight to and well as that pipe.
I also see a problem on the passenger side. There is a metal piece that sticks over the cover on the back side of the head at the fire wall. It holds the spark plug wires. I have no idea how I'm getting the cover off with that piece mounted. I haven't see that piece mentioned in the writeups. I'll have to get a pic tommorrow.
Though, I was expecting to do alot of gasket scrapping. But the gasket was an orange rubber piece. It looks similar to the blue Felpro piece that I got at Autozone. I hope the Felpro does a better job and doesn't leak.
